ftoomsh
Trailing Arms For More Neg Camber And More Toe In
ftoomsh
I am thinking of swapping the rear trailing arms with Xsara vts units.
I hear lots of people using 306 gti6 arms but the xsara vts arms give more toe in (0.72 I think)
So my query is are the torsion bars & arb going to be compatible
stu8v
Depends what you use it for and the balance preference you like
ftoomsh
Tarmac rallying
To answer your question, yes your existing torsion bars and anti roll bar will work.
Be aware that the Xsara/306 rear brake discs have a different offset to the 205 ones. All the bits are interchangeable though.
ftoomsh
Meaning that I would have to use gti6 / xsara rear calipers and discs ?
Or could I swap existing calipers n discs onto new arms?
ftoomsh
Forgot about the zx!!!!
Are there any left ???
you dont need to swap the calipers, they are the same other than piston size, its the disc+hub offset that differs
yes there are ZX's left...
Edited by welshpug
ftoomsh
Ah! so, so long as I use 205 rear hubs and discs I am fine then?
Edited by ftoomsh
or just buy 306/xsara discs.
stu8v
1 deg neg and parallel toe.
ftoomsh
The gti6 /xsara vts are 1.2 deg neg & .72 toe in does this not give better cornering grip and better top speed stability
stu8v
Maybe.
I guess it depends on preference.
Mine is quite mobile at the rear with these zx arms, 23mm torsion bars and 25mm a/r bar.
I kinda like it that way, we will see what its like on slicks soon....
allanallen
They've got more toe in than that afaik, I'm guessing you're talking in mm?
They're 1.2 neg and 5mm toe in, very similar to the later 309gti arms
Edited by allanallen
ftoomsh
Maybe.
Have you been out on slicks yet???
I've got 306 arms with 23mm bars, 25mm ARB and 306 brakes. It's a simple swap. I haven't measured the toe in, but I do know it's too much compared to standard. It's very predictable, you might say even benign. Not what you really want if you want to go fast. I'm going to give it a rejig to get some toe out.
ftoomsh
Surely toe in on the rear is going to give improved stability at high speeds???? is this not what is preferred?
Toe in = predictable
Toe out = fast
stu8v
yep awesome!
Biggles
Correct.
ftoomsh
So xsara vts ph1 arms would be better than zx 16v on a tarmac rallycar??
depends how you want it to handle, personally I'd use the ZX arms so it turns in better,
stu8v
I could do with a slightly stiffer front spring.
naaaahhh, that's fiiiine :D
