erbs 42 1 Cars Posted March 22, 2014 (edited) On my pug the front calipers are seized solid, is there a like for like calipers from later pugs like the 306 or something along those lines I could easily obtain from the scrap yard as a direct replacement on the same sized discs from the 1.6 Edited March 22, 2014 by erbs Share this post Link to post Share on other sites
pug_ham 243 3 Cars Posted March 22, 2014 You can fit the girling calipers & pads from a 1.9 with the correct bolts as well for a direct swap over the Bendix calipers orginally used on the 1.6 GTI. I have done this on mine. g Share this post Link to post Share on other sites
erbs 42 1 Cars Posted March 22, 2014 (edited) Thanks for the reply the reason why i am asking is that I'm not gonna find a 1.9 in the scrappy and i have seen loads of xsara's 106, 306's in my local scrap yard that is 5 mins away from my house rather than waiting for post easier for me and i can grab what i need off the cars plus any extra bolts that i can use last time i asked for a set of calipers i was charged a tenner for the pair so cheap too Edited March 22, 2014 by erbs 1 Share this post Link to post Share on other sites
pug_ham 243 3 Cars Posted March 22, 2014 If you find a newer pug with the same size discs (247mm) you can use those but put up a wanted ad on here & I'm sure you could find a set of the 1.9 calipers easily enough, maybe not for £10 though. g Share this post Link to post Share on other sites
Miles 331 1 Cars Posted March 22, 2014 Early Meganes and Clio's use the same calliper 1 Share this post Link to post Share on other sites
erbs 42 1 Cars Posted March 22, 2014 Early Meganes and Clio's use the same calliper Thank you Share this post Link to post Share on other sites
mowflow 67 Posted March 22, 2014 It is indeed. Both my calipers are fubar'd. I looked at rebuild kits but it cost about the same to just buy a brand new pair of calipers. I can't 1.9 calipers are usually pretty pricey and more often than not are being sold without the mounting bolts. Probably worth changing to the 1.9s if you can get them though. From what I've read they are more reliable. Share this post Link to post Share on other sites
erbs 42 1 Cars Posted March 31, 2014 went to the local scrappy and a found a perfect set of Bendix calipers ,all complete and no perished rubbers and pistons move freely all for a princely sum of £10 Bargain!!!!!!!!!!!!!!!! 1 Share this post Link to post Share on other sites
