jesse390
Cooling Fan Plug
jesse390
Could anyone tell me where the grey plug with the red and black wires, which come from the cooling fan motor go. For the life of me i can't remember or see any corresponding plug.
Thanks, Max
There should be a mini-loom for the cooling fan with the other side of the plug on it - the plug might be tucked up under the headlight panel on the passenger side.
jesse390
Yeah got the mini loom made up of blue and white wires coming from the shunt box but no large grey plug for the cooling fan. Could anyone tell me where the power cable that connects the grey plugs originates from so may me able to trace it back. Baffled
Thanks, Max.
Edited by jesse390
The mini fan loom connections are easy, it's fed directly from the shunt box (black box on slam panel) which runs to the fan switch, low speed resistor & fan motor, earthing at the common earth point on the inner panel for the l/h headlight.
g
