jimakos205
Cti-Remove Rear Window
jimakos205
Someone knows step by step to tell me how to remove the rear window (only the window no the roof) on my cti??need to replace the plastic..
ALEX
Been ages since I've took mine off, I'm almost ready to fit it.
I'm sure it zips at the top and clamped under a clamping bar at the bottom,
The sides are Velcro IIRC
pyrrhic
There is a zipper that is upside-down U-shaped that runs from one bottom corner to the other. After that you need to undo a 2" velcro strip on both left and right. Bottom part is held in place by an approximately 3-foot long metal strip that is accessible from the inside. Remove rear parcel shelv, and there should be 4 or 5 bolts (I tink 13mm) you need to remove. Then the whole thing comes out.
Edit: go to the Haynes 205 pdf (here: http://www.acc.umu.se/~mappo/peggan/HaynesP205.pdf), jump to page 184 for hood removal procedures including rear window.
Edited by pyrrhic
jimakos205
thanks... :D:D
