claypole1360
Split Ends.
claypole1360
Evening all,
the last time I removed track rod ends, it was on a triumph Herald and required brute force, a lump hammer and a ball joint splitter, is this still the respectful way to remove a track rod end from it's fixing or have we moved on a bit since then?
Thanks, Calvin.
deathbringer929
more or less, yes. take care not to damage the dust covers if not replacing tre's
claypole1360
Thanks Mate. Will need to get a ball joint splitter then. Calvin.
No need, just a few decent thumps on the side of the hub where the pin taper is and they pop out.
claypole1360
Cheers Mei.
