Ian205
Are Front Brake Lines Common Between 1.6 & 1.9?
Ian205
as amove, ordering new braded lines from HEL, they dont have any front lines listed for 1.6, just 1.9, are these common?
thanks
Front brake lines are the same, rears are different.
Slo
Braided hoses don't fit some cti/base models out the packet because the hose bracket under the wing is facing the wrong way, I found out mine was wrong when I fitted swampys kit. Had to cut em off and re-weld em 90 degrees
