yorkshirekowboy
Will A 205 Auto Postive And Negative Lead Set Fit A Gti Model?
yorkshirekowboy
Hello, I'm needing a positive lead with the shunt box attached and the two feeds for the starter and alternator, also a negative lead set with the quick release battery terminal. I have found both but its from a base model, automatic I think. Would these be ok for my mi16 engined 205?. Length/thickness of wire. Shunt box the same?
Regards Danny
Edited by surferkid205
likely to be the same part given the auto's are all XU engined afaik.
though given the age of them, you're better off getting new cable fitted to fresh terminals.
Edited by welshpug
yorkshirekowboy
Yeah thanks. Thinking they would be the same. Thanks again Danny
yorkshirekowboy
Sorted now thanks.
Guest
