bobdylan_55
Fuel Sender Resistance And Connect To Digi Dash
bobdylan_55
Hi people,
Just wondering If anyone was able to help with a few electrical issues I have.
I have just wired in a digidash but its resistance settings are either 100 or 510 ohm.
Firstly, does anybody know what a 309 gti senders resistance is?
Secondly, how can I convert/adapt the wiring to change the existing options to suit the 309 senders resistance?
thanks
Bob
Edited by bobdylan_55
GilesW
Which dash is this Bob?
I'm just about to have the same problem with a koso dash I'm putting in.
bobdylan_55
Same haha
I've managed to wire all the lights etc just trying to get speed and fuel working now.
bobdylan_55
Anybody help?
It has a max. resistance of approx. 280 ohms. As it's only a 2 wire sender you usually have to add a pull up resistor and add voltage, to make a voltage divider circuit. Thus my output is now 0 - 2.5V, from a 5V supply voltage.
bobdylan_55
Thanks Pete
Any chance you could explain to a thick sod like me? :D
I understand the principle I think. You are halving the voltage and hence with the same resistance from the variable resistor we get a different current? I.e. r=v/I?
In this case is it actually the current that we get the output for the fuel gauge from?
Also if its 280 ohm Max resistance and I half the voltage i presume it would be close but not 100% correct for the 510ohm setup?
pip470
Topic resurrection. If I connect 12 the fuel gauge goes to 3/4 and then when I tip the sender it goes to full. Can some one draw a circuit of what I need to add to make this work. Many thanks phill.
