MikeC
Rear Beam Part Numbers 205 Gti
MikeC
Hope ye can help.
I am looking to source a beam repair kit, and am wondering if anyone has the SNR part number for the two needle roller bearings on the the rear beam for a 205 gti?
If ye have the SNR part numbers as we have stock in work.
Also would anyone recommend bearing kits for same beam?
MikeC
Would these be all the parts i need for a rebuild?
5176 17 Trailing arm shaft
5172 24 Anti roll bar bearing bush
5174 03 Crossmember seal (anti roll bar lever)
5132 49 External bearing
5131 45 Internal bearing
5154 05 Plug
5154 08 Suspension arm seal
5154 09 Cup
5154 10 External seal (suspension arm seal holder)
5153 12 Suspension bar washer
5153 11 Crossmember screw
5153 10 Suspension bar stud
6962 66 Spring washer
6932 38 Hexagonal nut
Still wondering if anyone has anSNR part number, or are they any good?
jord294
Bare in mind that if you went to main dealer for them parts, some parts will come in quantities of more than two
