artois7
Clutch Cable (I Know This Has Been Done 100 Times)
artois7
Hi all,
I know this thread has been done before but I couldn't find my particular answer, or maybe I didn't look hard enough!
I need a clutch cable and want to get it local. I have a 1987 phase 1 1.6, with reverse light up above first, so BE1 gearbox I believe?
The cables listed for my car are different at GSF and euro, so here's the euro:
http://www.eurocarparts.com/ecp/c/Peugeot_205_1.6_1987/p/car-parts/car-transmission/clutch-and-associated-parts/clutch-cable/?646735168&1&cab23982a32969434011ceaa355b36c8213d7331&000063
Length: 1557mm
And here's the GSF:
http://www.gsfcarparts.com/715pc0290
Length: 1440mm
The GSF part is almost half price but obviously different lengths. Which do I need? Help! :)
euro pic is correct for BE1, GSF pic is for BE3.
your car if original would have the earliest type BE1 cable.
artois7
I'll get the Euro one then!
FYI - they're the same company (as you probably know), but use PARTS25 discount code and 25% off makes the cable £13.28, so cheaper again :) plus they're opposite my work so that helps.
Thanks!
Edited by artois7
artois7
SAVEME75 is a 7.5% discount code I've just found for CP4L :)
