Mattr5uk
Be1 Clutch Release Arm
Mattr5uk
A bit of advise would be much appreciated on this as I'm sure obtaining a replacement arm won't be the easiest thing.Upon removing the gearbox today the clutch release arm came away from the nylon bush that pivots on/over the ball joint. I've only looked at it quickly but it appeared to me the bush is effectively bonded to the arm through the 2 small holes in the arm and has come away. Could anyone tell me Does the bush usually pop over the ball joint or pivot on top of it?
should clip over the ball joint so to speak, sure I have one kicking about here somewhere if you need one.
Mattr5uk
Am I correct in thinking the ball joint "pops" over it and pivots directly on the metal lever arm then? I know the renault 5 use to have plastic cap over the ball joint. Can you see any problems with bonding it back to the arm? Thanks
