forbeslongden
205 Stdt Injector Help.
forbeslongden
Hey guys,
When I bought my STDT I noticed that one of the injectors let's a bit of fuel out, more than likely it needs replacing, right/
If so will lucas part no HRD173 be suffice?
Is it the injector or just the bleed off pipes that link between the injectors?
These are only rubber & can perish/split which will give you a leak.
g
forbeslongden
It's at the base of the Injector where it goes into the cylinder head(?) it only seems to do it sometimes as I took it to a diesel specialist and they didn't see it do it, I've seen it though...
