flyfisher
Will It Run
flyfisher
I've just purchased a 1905 alloy mi 16 engine from a forum member this unit has been run on throttle bodies and mappable e c u. It has cat ams vernier pulleys ect in the short term I want to use the standard set up. Until I can afford t/ bodies ect car currently has mi 16 in it running on standard 405 mi ignition So as said will this work any info would help please
depends how wild the cams are.
flyfisher
Cams are catcams 4900527 inlet 4900526 exhaulst. Hope this might help
flyfisher
Just looked on cat cam web site they say4900527 is for hot street. That's the inlet cam and 4900526 is a sport. Is the exhaulst
dcc
It wont run well, or as well as it should, but it should run ok
calvinhorse
It wont run well, or as well as it should, but it should run ok but how many wood chocks could a wood chuck chock if a wood..
2052NV
it should run fine. ive got verniers and 283deg cams in mine running on standard managment and intake. Not running to 100% potential but still hauls ass ^_^
2052NV
oh and idle's more solidly on 1000rpm than any MI i know of ftmfw
