Ian205
Can Some Identify My Exhaust System?
Ian205
as above, this system came on my 205, it has no manufacturer stamp, although it has a matching seriel number or code on the 4 branch mani, the mid section and rear section
the code is
XP22
MANA-XP22
C20J32M2
here is a picture dsc_0014.jpg​
thanks
magnex.
Ian205
that was fast! are these a good system?
mowflow
No. I'll take it off your hands if you want.
Alan77
Just google about a bit, they were about £450 for the whole system new. A full used one went on ebay for £335
Give it a clean and keep it if it works fine.
Simes
I had one 15 years ago! I bought it second hand from someone who had bought it 10 years previously but not used it for 8 - £160 I think.
Good, long lasting - make a nice sound and a period mod. The manifold is claimed to give more torque.
I did think it was a little smoother from around 2-3krpm on the old 8v.
When I went Mi16 I kept the centre and backbox and fitted it to my maniflow 4-2-1. I sold the magnex manifold to someone on here for £100 back in 2003?
Sold the rest about 4 years ago.
Fit a stiffer lower mount - they originally were sold with one, stops the down pipes hitting the bulkhead.
Ian205
nice to know that its a good system! the mid section an rear section are standless but the exhasust doesnt look to be? or else its very heat stanied
check it thoroughly for cracking, the manifolds are notorious for it.
allanallen
If you're going to use it I'd be tempted to get the pipe to flange on the manifold properly welded, they're a bit s*it as standard and as welshpug says they crack for fun!
