johniban
T16 Manifold
johniban
Looking into buying a t16 exhaust manifold but i don't want to spend too much on it being that its only a cast item, i know they are rare so i expect to pay more than normal, but how much do you think one is actually worth?
The lad reckons he paid £800 for it witch i cant see considering you can get a custom equal length one made up for around £600
I want to buy it but don't want to pay over the top for it then loose out if i come to sell it later on.
dcc
why do you want it?
I think one sold for 150 recently
peugeot price for them is £800 plus vat.
Oh, so it wouldnt be much good for you anyway then.
dcc
different heads.
johniban
its come from a gti6. has had the ports elongated and extra studs drilled im guessing
dcc
sounds a bit bodged. I have no idea if it will clear the bulkhead in a 205 or even the gear selectors.
if you decide to buy it and not use it, you will struggle to sell it because it has been f***ed with and isnt original, and likely to be utter s*it anyway.
johniban
Thinking about it, that makes sense, ill think ill give it a miss
dcc
looking at those 2 photos youve posted, they look like different manifolds. bit hard to tell the first photo is so small.
if you want a turbo manifold for a gti6 further down the line, buy yourself a welders nightmare from dp
hcmini1989
Pretty sure these are prone to cracking aswell so i would `nt bother .If you did decide you wanted one id message ALEXN off here i remember he had one a (cracked one) going easy enough to get it welded/brazed.
B11 BOB
I have one available if you still want one.
johniban
how much
calvinhorse
That one is cracked anyway, it's eBay
Thought you were going carbs as you didnt want complicated ecus and wiring :lol:
johniban
the manifold it nothing todo with the car i have at the moment
B1ack_Mi16
It's a bodge using it on the GTi6 head anyway I would say. Ports match very badly.
johniban
not using it anymore, can see me having issues. and people want stupid money for cracked ones
