dee205
Can Anyone Decode A Vin Please
dee205
Not sure on where best to post this but this is the VIN sticker on the pilar of a 2008 2.0 HDi 136bhp 407SE. So it all says on the tax book.
The thing that struck me was the model sticker... Says 2.2 hdi 170bhp. But it's a 2.0 engine as I've checked the engine code.
It doesn't look as if someone stuck it on and it's a one owner car from a company.. It set off alarm bells with me although the car looked 'straight'
Is anyone able to decode the VIN for me to see what comes up?
dee205
Yeah it doesn't show it but it's an NI reg so thats common enough. It's probably legit but the sticker has threw me off big time.
Rhr is the engine code, servicebix would tell you too, its a 2.0 136 engine.
derp, ran out of edit time.
servciebox says:
Vehicle family 407
Build code 11426 CJ 2 0197
Warranty Start Date 15/05/2008 BER e2*2001/116*0297*07
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT
VEHICLE FAMILY 407
SILHOUETTE 4 DOOR SALOON
TRIM LEVEL HIGH HIGH
ENGINE DIESEL TURBO DW10BTED4 TRANSMISSION BVM6
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR KTV - BLACK PEARL PAINT
INTERIOR TRIM TYPE ANDOR GLOSS BRAID + OMNI "XH"
UPHOLSTERY COLOUR "FT"
GEARBOX (CHARACTERISTICS) BVM ML6 CL
ENGINE (TYPE) EW/DW
Vehicle characteristics
INTERIOR TRIM TYPE ANDOR GLOSS BRAID + OMNI "XH" UPHOLSTERY COLOUR "FT"
STEERING UNVARIABLE POWER STEERING
Fuel supply-Engine
TANK FILTER CITHOUT RESERVOIR FILTER
THROTTLE HOUSING (ENGINE INLET AIR CIRCUIT)
MOTORISED THROTTLE BODY (ENG AIR INTAKE)
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL FUEL EMISSIONS STANDARD (ENGINE)
ANTI DEPOLLUTION L5 (ENGINE)
ENGINE (TYPE) EW/DW
OIL COOLER MNTG WATER/OIL EXCHANGER ON ENGINE
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE) STANDARD
POWER EOBD SELF-DIAGNOSIS SYSTEM "EOBD" SELF-DIAGNOSIS
DEVICE (ANTIPOLLUTION) "EGR" EXHAUST GAS RECYCLING
VEHICLE TECHNICAL DEPOLLUTION L5 VEHICLE TECHNICAL DEPOLLUTION
PARTICLE FILTER PARTICLE FILTER
FAN 1 ELECTRONIC FAN INTEGRAL CTRL 150W
INJECTION ASSOCIATED VARIANT MOUNTING DELPHI
Gearbox Transmission
TRANSMISSION BVM6 GEARBOX (CHARACTERISTICS) BVM ML6 CL
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 17 X 71
WHEEL STYLE 16 INCH HORTAZ WHEEL
CLUTCH HYDRAULIC CLUTCH DIFFERENTIAL (GEARBOX) DIFFERENTIAL 86
RIM/TYRE SIZE 16 INCH
TYRE FITMENT TYRE (SIZE, TYPE) 205/60 R16 92H NON REINFORCED TYRE
WHEEL (TYPE) 6 ALLOY WHEEL FITTING
INFLATION PRESSURE LOSS INDICATOR WITHOUT TYRE DEFLATION INDICATOR
GEARBOX TYPE ML6C
Suspension-Steering-Brakes
STEERING (OPERATION) ASSISTED ELECTROHYDRAULIC
STEERING STEERING COLUMN MANUALLY ADJUSTED STEERING COLUMN
FRONT ANTI-ROLL BAR FRONT ANTI ROLL BAR DIAM 24
STEERING TRAVEL TRAVEL MECHANISM STEERING 184
SUSPENSION NORMAL SUSPENSION
ACTIVE SUSPENSION WITHOUT VARIABLE SUSPENSION
DYNAMIC STABILITY CONTROL
SYSTEM ELECTRONIC STABILITY PROGRAM
BRAKE ASSOCIATED VARIANT 8 1 BOSCH ESP
Body fittings
HANDS FREE ACCESS AND STARTING NO ACCES AND HANDSFREE STARTING
TOWBAR WITHOUT TOWBAR
SIDE MOULDINGS (TYPE) SIDE TRIM BODY COLOURED + CHROME SIDE MOULDINGS (DIMENSION)
LATERAL PROTECTORS + SIDE SILL
WHEEL EMBELLISHER (STYLE) WITHOUT WHEEL CAP
SILL ILLUMINATION LAMP SILL ILLUMINATION
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTION ELECTRIC FOLDING EXT REAR VIEW MIRROR NO MEMORY
WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
REAR SCREEN WIPER W/O REAR SCREEN WASH WIPE
HEADLAMP WIPER W/O HEADLAMP WIPER
FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG
ROOF GLASS WITHOUT ROOF WINDOW
SPARE WHEEL EMERGENCY WHEEL
EXTERIOR ACCESSORIES BODY COLOURED EXT HANDLES + EXT MIRROR
SUN ROOF FIXED ROOF
BUMPER TRIM MATT COLOUR
BUMPER STRIP + STAINLESS STEEL TRIM
GLASS (APPEARANCE) WINDOW TINTED
WINDOW (TYPE) ACOUSTIC LAMINATED WINDSCREEN+TOUGHENED RR SCREEN
Interior fittings
DRIVERS KNEE AIRBAG DRIVERS KNEE AIRBAG
ANTI-THEFT ALARM ALARM ULTRASONIC+PERIMETER STD
REAR SEAT ARMREST WITH REAR ARMREST
REAR SEATBELT REAR 3-POINT 3 INERTIA REEL SEAT BELT
CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES
CHILD LOCK ELECTRIC REAR CHILD LOCK
SPEED GRADUATIONS GRADUATION MPH
DRIVING POSITION RIGHT HAND DRIVE
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
DASHBOARD EQUIPMENT SATIN SILVER DECOR
INSTRUMENT PANEL (CHARACTERISTICS) GRADUATION 260 KM/H OR 160 M/H
LIGHT BACKGROUND DOOR TRIM SQUARE DECOR
LOUDSPEAKER 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS
RADIO CONTROLS REMOTE RADIO CONTROL
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT REAR BLIND
FRONT PASSENGER SEAT HEIGHT CONTROL FRONT ADJUSTMENT PASSENGER SPACER
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
FRONT PASSENGER SEAT ADJUSTMENT PASSENGER LUMBAR ADJUSTMENT
FRONT SEAT ARMREST (OPERATION) FRONT ARMREST MANUAL
COMPACT DISC WITHOUT COMPACT DISC SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM
HEADLAMP BULBS HALOGEN BULB
REAR WINDOW LIFT SEQUENTIAL ELECTRIC REAR WINDOW + LOCKING DISPLAY DISPLAY (RADIO+CLOCK AND OR TEMP, CD)
COURTESY MIRROR DRIVERS + PASSENGERS CONCEALABLE WITH LIGHT
OIL GAUGE TWO-FUNCTIONS INDICATOR OIL LEVEL+TEMPERATURE
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG THORAX SIDE + CURTAIN AIRBAG FOOTWELL
LIGHTING WITHOUT DOOR SILL LIGHTING
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
DIRECTIONAL HEADLAMP WITHOUT DIRECTIONAL LIGHTS
RADIO RECEIVER "RD4/MP3" RDS COMPACT DISC AUDIO SYSTEM
REFRIGERATION AUTOMATIC AIR CONDITIONING
CRUISE CONTROL REGULATOR OR SPEED LIMIT
DRIVERS SEAT HEIGHT CONTROL DRIVERS SEAT HEIGHT MANUAL ADJ INTERIOR
REAR VIEW MIRROR ELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR
AIR CON./TEMPERATURE REGULATION AUTOMATIC AIR CONDITIONNED BI-ZONE
TUNER RADIO DUAL RADIO TUNER
OBSTACLE DETECTION SYSTEM WITHOUT OBSTACLE DETECTOR
LATERAL BLINDS WITHOUT SIDE BLINDS
TRIM ADAPTATION LEATHER GEAR LEVER KNOB
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
LOCKING CONTROL CENTRAL DEAD LOCKING
WINDOW (TYPE) ACOUSTIC LAMINATED WINDSCREEN+TOUGHENED RR SCREEN STEERING
WHEEL LEATHER STEERING WHEEL 3 BRANCHES FAN 1 ELECTRONIC FAN INTEGRAL CTRL 150W
Electrical
ALTERNATOR ALTERNATOR CLASS 18 180 AMP
BATTERY BATTERY L3 450
STARTER MOTOR STARTER MOTOR CL 5
SPECIAL LIGHTING AUTOMATIC HEADLAMP ILLUMINATION
EXT REAR VIEW MIRROR NO MEMORY CEN.
LOCKING REM CONTROL FREQUENCY LOCKING
REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE
FOOTWELL LIGHTING WITHOUT DOOR SILL LIGHTING
RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
SURFACE CONDITIONS GOOD TERRAIN EXTERIOR
SLAVE CONTROL UNIT BSI EVOLUTION
