Ian205
Identifying A Cam?
Ian205
hi guys i took the engine out of my 1.6 8v 205 yesterday for body work perposess , when the engine was out i noticed there was a kent cam pulley and a piper cam fitted by a previous owner.. would these be a good mod? and how could i find out the model of cam as i understand theres a few different models, road, fast road, track, rally etc
also where could i go from here performance wise?
thanks
It should be stamped on one end with a model number - probably be KC PT36 I would imagine if it's running OK on standard management
Ian205
its still fitted to the engine so i cant see ether side, what would that seriel number translate to? i presume just a upgraded road cam? i presume its running standard engine managment, wheres the ecu in these? pardon my ignorance!!
