Bobbafett
1.9 8V Intermittent Loss Of Power.
Bobbafett
Hi there. I bought a 1.9 GTi a few weeks before Xmas, and when I bought it it drove like an animal, pulled mega-hard all the way through but drank a phenomenal amount of fuel. It was also 3 litres short of oil!
Since then I have replaced the:
Oil + Filter
Plugs and Leads
Air and Fuel filters
ECU Temp sensor
Lambda Sensor
Cambelt, tensioner, Waterpump
and
Cleaned MAF and Throttle Body
Now when I drive it, especially at cold there is a massive flat spot between 2-3k RPM, but also intermittently it is completely losing power and not revving over 2500rpm, even when totally hot. You put your foot down and there's almost resistance from the engine and nothing there. Happens totally at random and lasts for a random period of time.
Any ideas?? I haven't driven it much in between changing all these things so hard to pin down which it could be.
farmer
No expert on these issues
Could be a dodgy ignition amp?
Bobbafett
Possibly. It was unsecured when I bought the car but i've mounted it now with some heat paste behind it and a couple of new bolts.
It's really annoying when it happens because otherwise she's running as good as ever. 2 things I did notice that are now different is it takes a lot longer for it to start than it did. I have to turn it over for 4-5 seconds then it kinda splutters roughly into life whereas before it used to start almost instantly. And now the plugs are white where as before they were black (the reason I changed all these things is because it was running very rich).
Could the fuel filter be the issue? Funnily enough i'm fairly certain I first noticed it after the fuel filter change. I did pull the fuse from the fuel pump when the car was running to de-pressurise the fuel when I did it. Could it be the pump? This is the fuel filter I fitted:
http://www.eurocarparts.com/ecp/c/Peugeot_205_1.9_1993/p/car-parts/car-service-parts/regular-service/fuel-filter/?503440128&1&25aa0c16be064e5ed34c60693c59edee180b0af5&000140
farmer
If its white it's running lean.
Have you got it all set up correctly by a garage ?
Bobbafett
Don't think there's much to set-up, it's a late car (93) with a Motronic ECU.
farmer
White plugs certainly point to a running lean issue.
Bobbafett
Yeah, i'm guessing that's because of the new Lambda. This intermittent power loss started before that though. Think i'll change the fuel filter back to the old one and see what happens!
Bobbafett
Could a dodgy tachometric relay cause this??
farmer
When my relay failed I was left at the roadside.
Not sure if they can be intermittent with a fault.
Bobbafett
It's almost as if suddenly the supply of fuel is interrupted when it happens. So i'm looking at either the fuel pump, the relay or the filter. The fuel lines aren't kinked or anything. But could a new fuel filter cause something like this?
farmer
To be honest I would doubt the fuel filter is the issue.
Have you got another relay to try.
Don't go to Pug if you want a new one there 3 figures.
Euro car parts have them.
Bobbafett
Can't find one on ECP. GSF have one but it's £50! Might have the existing one out tomorrow and see if cleaning up the contacts helps!
farmer
There not cheap.
Pug charge about 120 quid if I remember right.
Give it a try and just try and rule out one thing at a time.
Have you tested the pump direct to a battery ?
Bobbafett
Well the pump is obv working most of the time, but it's like it's cutting out intermittently for a short time. I might just be clutching at straws here I don't know. Just annoying i've done all this and now have a problem I didn't have before!
farmer
Try the relay, they are prone to faults.
Bobbafett
Just took it out, it's worse than ever. No power there at all and kept trying to stall.
It appears I don't have a tachometric relay. It is a late 1993 car.
farmer
Unfortunately I do not know much about the phase 2 engine management, having never owned one.
MikeC
Best get a Workshop manual and go through the setup/tuning procedure.Did you look at your AFM?
Bobbafett
I did yes. I cleaned the track with contact cleaner but there are 2 black grooves in it. Unfortunately I can't find a guide to retrack my particular AFM. I know it came out of the Cavalier or something but supposedly it's the same AFM (it has the same part number). I'm wondering if the spring tension needs adjusting to make it run slightly richer? The plugs are bright white.
My other thought is could the alternator failing cause these symptoms? I've thought it wasn't working very well from the start.
Sounds like classic knackered Air Flow Meter to me.
Bobbafett
70bE794.jpg?1
This is my AFM. I've adjusted the spring tension 2 teeth counter-clockwise to try and richen it up a bit. What is the screw attatched to the small strip of metal which is attached to the blue rectangle?? If you continually screw it in it clicks very faintly. What should it be set to??
MikeC
These are factory set so be careful with it. There is a re-tracking guide on here, or a link to one on here somewhere.
Bobbafett
I have turned the screw linked to the blue thing, so wouldn't mind knowing what that is!
Mixture potentiometer.
Bobbafett
Any idea where that should be set? Moving it doesn't seem to change anything.
