dobboy
Part Number Please?
dobboy
Can anyone tell me the part number for the big plastic cover over the coil packs?
Slo
Do you mean the plastic bag?
Or number 5 in the picture 5966 04
Edited by Slo
farmer
Have you asked for 2nd hand anywhere?
Edited by farmer
dobboy
Thanks, but its the big plastic cover that sits between the rocker covers on the gti6 engine.
It's 597990 and it's £14.69 inc VAT. Not listed as NFP so presumably still available.
dobboy
Got it ordered.
Anthony, i have the pug software for part no's etc similar to the type of which the image above was captured, but it doesn't show the part i was looking for.
How did you manage to get the number as there a few little clips and bits and bobs i would also like to renew?
I use the Peugeot Servicebox website - clicky
The coilpack cover for example is listed under the following, once you've selected 306 and the appropriate engine:
"Mechanical" -> "Engine" -> "Ignition" -> "Engin Spark Plug Ignit Electr Modul Coil"
Should all be on the older Peugeot Parts CD too if that's what you're using - the only disadvantage is that you can't find out the price and whether the part is currently listed as NFP or not.
dobboy
Thanks Anthony. I'll be having a look at that.
dobboy
Anthony, signed up and looking through service box..... looks good!
Do you need to be a legit garage to get the actual price for the item?
and secondly.....
is it usual practise to replace item "15" (i already have a new Vibra tech's item 13) when doing a conversion?
Thanks in advance
farmer
If the bush is looking tired I would replace it.
dobboy
Thanks guys, if its cheap enough I think I'll change it anyway while I have easy access.
dobboy
  On 1/16/2014 at 10:49 PM, farmer said:
£18.42 is the retail.
Thank you for your help, I'll get it ordered tomorrow and add it to the pile!
dcc
Id replace with a genuine item. Youre likely to hate yourself for using a vibratechnics thing. They were damn awful on my old c2. That little bush '#15' makes a massive difference to engine vibration in cabin iny experience.
dobboy
DCC, yeah i will get a genuine #15.
The rest of my new mounts are genuine, except #13.....
So i'm hoping the combination that i will have will be enough to stop the the engine tilting and maintain a wee bit comfort.
theo-mi16-gr
As far as you use Vibra, the little bush gets extra stress.Mine was almost ruined as i have a group N main bush.I ll replace with an oem soon.I hate all this vibration in cabine cuz of the solid one.I believe no need for it if it isn't used as track/rally car.No tilt issues with original item.I prefer to replace the oem when needed instead of loosing the convenience and make all the car rattling! I wish had this knowledge earlier:)
dobboy
Hi Theo, i'm hoping that the vibra stops tilting, and the new pug ones help give a decent level of comfort in lieu of stiffer options..... i'm assuming none of my mounts/bushes have ever been changed........ and i can see a bit of engine movement just now with the 1.9......... so while i've got a relatively easy chance when engines out, i'm gonna take it.
Edited by dobboy
Turning the OE mount thru 90 degrees is a good way of helping engine movement without any downside's.
