DC2T 50 Posted January 5, 2014 I apologise if this has been covered but i couldnt find it with a search, i want to remove my doors as theyre getting in the way at the mo. I thought it was just the 4 bolts so removed them to find the check strap didnt just pop through, so i loosened the check strap and again it just didnt come through, do i just need to tap the roll pin through to seperate the check strap? or is there something else ive overlooked thanks in advance Share this post Link to post Share on other sites
Redtop 14 2 Cars Posted January 5, 2014 Yes you need to knock the roll pin through on the checkstrap. Your door will be either held on by 2 double roll pins, or on the fresher cars 91 or so on, it will be 2 torx bolts at the hinge. I always found it easier to remove them here, rather than at the bolts, means your door gaps don't need re adjusting come fitting time. Share this post Link to post Share on other sites
DC2T 50 Posted January 5, 2014 There were no torx bolts i could see, only a rollpin with a rollpin it looked like. Its only a base model so i duno if itd be different. Ill get my punches from work tomorrow and knock them out Share this post Link to post Share on other sites
DC2T 50 Posted January 6, 2014 Just got it off, i see the torx screws you mean now and agree itd have been easier to remove those. Lesson learnt Cheers Share this post Link to post Share on other sites
