Daniel306
Replacing Quatter
Daniel306
Going to replace the quartet panel, the panel separated from the inner arch and has caused rust along the inside and rotted under the arch trim, im also planing to change the rood skin for a non-sunroof, iv got a spare shell that's rotten but has got the parts i need in good condition, has anyone got any photos or a guide for it?
there's a few topics that have covered both tasks briefly, namely craig's lazer resto had both quarters iirc, and paintguy did a roof swap a few years ago.
Daniel306
How did you find it, not too hard really?
Im currently replacing the front panel, both front wings, fitting new radiator and an intercooler. The drivers side lower door hinge has rusted from the inside out too.
Daniel306
Not too sure how im going to fIX this one yet
should be a fairly simple repair, cut out a square around the hinge, remove hinge from the remains of panel, let in a square of fresh metal, weld hinge back to pillar.
perfect opportunity to fit a new hinge if you have worn ones, or at least to repair the ones you have.
Juttie205
You not doing your dimma anymore?
Daniel306
Not with this car, don't want to fit a kit one a clean one
Daniel306
Is it just bonded on along the sill?
farmer
If you are wanting / needing a new hinge I have some I think.
Comes with new door pin as well
Daniel306
I was planing to cut the complete section from the scrap car, just removed the quartet, what looked good on the outside was rotten on the inside
Where can i get a new quarter?
Ebay, breakers, dealer.
Daniel306
Dealer? still get them new?
Juttie205
Spoox motorsport have a brand new n/s one but bit pricey at £360
Daniel306
Is there many motor factors that sell panels? Ecp don't list them but il phone them tomorrow and see if they can order them
farmer
I would think the rear quarter panel is dealer only.
Daniel306
There are non genuine out there so there must be someone making them
Edited by Daniel306
farmer
Finding them is a tricky part, I have a couple reserved for me in Belgium.
Its the shipping that is the problem.
I wonder how the pattern ones will fit mind ?
Daniel306
If there rust free il make it fit
