jamie_1992
Longer Speedo Drive For Gti6
jamie_1992
A while back I read a topic on where to get a longer speedo drive for a 205 converted to gti6 with 205 gear box but can't find it
Dose anyone know what I need or a link to the topic
do you mean the speedo cable?
camgti
I think he asking is
Is thre a longer cable that can be used to get more clearance what a GTi6 motor is fitted?
Mine is super close to the headers also but yet to have any problems. It would be nice to gain more clearance to tidy it up a little.
Is there a longer cable that works with a 205 cluster..
Cam
Edited by camgti
if he is asking that, then yes, 405 cable is about 4-5" longer and fits fine.
However IMO it wont really help, best option is to find some heat shielding material and add more to the existing original protective sheath.
jamie_1992
Yes I was on about the cable being longer I knew there was one just couldn't remember what one it was mine keeps pulling out the back of the dash
camgti
4-5 inches would be nice! Definitely make a difference on my car. Mine is about 2cm away from the exhaust at the minute.
Cam
That's the thing, due to where the cable goes you just can't avoid it being close to the manifold.
Jamie, just sounds like the clips are broken.
jamie_1992
Could well be if I have to buy new might be worth getting the longer
Edited by jamie_1992
Jolly Green Monster
mine seemed miles away.. will check length of the two cables I have
I would imagine that any 405 RHD cable should fit.
I recently fitted a speedo cable I removed from a late 405 diesel onto a 205 GTi-6 recently and it fitted fine once you moved the ball that sits in the bulkhead grommit along a bit. It gives a nice bit of extra length and now sits well away from the exhaust manifold.
As said, I would be tempted to add some form of heat protection to it anyway for long term protection.
The only issue with the 405 cables is that they don't clip onto the back of the 205 clocks properly. Not a major issue as I just leave the cable inside the car a little too long so that it's pressing against the backs of the clocks once they're screwed down and won't be going anywhere.
All 405 rhd cables are the same, i thought they did clip in fine, though its been a while since i've had a 405 dashboard apart.
I remeber someone asking about using an electronic speedo head, as simple as a cable is, electrickery seems quite tempting now, no bouncy needles and melted cables.
That was me and I have what appears to be a suitable speedo head at home, just need to test the theory in the New Year :)
I can't vouch for all 405 cables, but certainly the two late 405 diesel OE speedo cables I removed from cars in a scrappy both had a fitting at the speedo end that won't clip onto the back of 205 clocks properly.
The new OE 405 cable I've got still in a bag from Peugeot does have the usual 205 style fitting however, so I'm not quite sure when they changed. The new cable also differs where the ball is - the original cables have a ball inside a fixed grommit, whereas the new OE cable just has a ball, again like 205 cables.
allye
You are correct Anthony, the 405 cables do not have the little clips on the end. I ended up using tiny cable ties on the end to secure it as I got fed up of the speedo not working! I covered it in heat protective material too.
Just found a picutre
jamie_1992
ok so i ordered a cable for a 405 from gsf carparts they asked me for make and model so made it as close to mine as i could same year and a 1.9 petrol
the cable turned up today and is way to short not sure if they have sent the wrong one or not
here is a pic of the one they sent and a broken standard gti one
is that part number right?
il have have to get it changed what shall i ask them to change it for ?
Eejits, its for a lhd car, all rhd 405 cables are the same.
Oh yeah, i said that earlier :lol:
jamie_1992
oh dam looks like il have to convert the car to lhd
marksorrento205
FKS2030 is the part number on the bag of the last one I had :) That was a 405 RHD
shalmaneser
I've got a 405 cable and it had clips... Can't remember which one it was though, sorry! Works a beaut.
