Plumbob
[Car_Restoration] Scruffy But Original 1.9 Gti - Restoration
Plumbob
  On 11/8/2014 at 1:55 PM, Supersport2 said:
Have you plated the stuff yourself?
No there's a company just round the corner that does it for me. Reasonable prices too.
dobboy
Plum, if you don't mind me asking, what sort of money would the 6 items in your pic above cost to get plated?
I'm thinking of getting some stuff done
Plumbob
In total I've spent £50 there. For that I got the following done...
Front brake calipers
Rear caliper pad carriers and spreader plate things (dunno what they're called)
Fuel filter bracket
Bonnet catch
Shunt box bracket
Heater matrix bulkhead plate and bulkhead hose double clamp thing
Fuel tank strap
Gear lever quadrant
And a few various bolts....
Think that's about it. Seemed a reasonable price to me...
Edited by Plumbob
credowan
I'll have to take you for that spin before it goes into winter hibernation which won't be long at this rate but I've got a Vts box on mine
Gary
dobboy
Cheers that sounds a good deal.
I'll need to find somebody local
Juttie205
for plating I would recommend electroplate uk I have just given them every bracket I could find every bolt all caliper yokes hubs it totalled to quitea large box of bits and only £35
mrfirepro
Another vote for Electroplate here, it seems that no matter how much I send them it £35, I think it goes into there Xmas fund. :D
Plumbob
Weekend pics! Sunroof back on... Plasticared the trims.... I'll let the pictures do the talking....
48E2CB8F-6E1A-4748-AA34-40D851A809DA_zps
F8E5F588-0445-4EA1-A202-8AD29C0489FD_zps
13678DF3-833B-4BF0-8256-265671A63AB7_zps
851AA933-37E8-4D08-8DFE-946C2EFCD34D_zps
dobboy
It's coming together nicely.
Looks great.
speno
Sweet wheels
oh and nice paint too :P
Plumbob
  On 11/10/2014 at 1:36 PM, speno said:
Sweet wheels
Thanks!
Still waiting for a project thread for your Dimma!
speno
  On 11/10/2014 at 6:02 PM, Plumbob said:
Thanks!
You will be waiting a long time :unsure:
mrfirepro
I guess you may know, but there is a rubber strip missing from your sunroof. (on metal upstand in front of the sunroof leading edge)
Plumbob
Yes ta. I've got it, I peeled it off when I resprayed the sunroof tray. It's only about 8" long on mine though, and was just glued in the centre. It'll get it glued back on when I'm doing all the finishing touches. It's currently safely tucked away under the sunroof glass where I can't lose it!
Plumbob
Managed to get back on the rebuild after some time away....
Started by cutting out some new underfelt.
1B58CAA5-981E-4721-9E6D-45561618C08F_zps
Then began putting the interior back in, I'll let the pictures do the talking..
C8F1DFC7-2C62-40FC-8AC1-0C0A9A276487_zps
CF4CABA0-5BE8-48C2-9B2C-5DA469DA6128_zps
0925DC20-53AD-41B3-9ED4-E63B4D64F6AC_zps
BAB99268-75F9-40B7-87A7-BDE56A2EAD53_zps
3C357C17-5B84-4439-B0DF-D6E689B86481_zps
E157264B-1D9C-4929-B936-6CB21DD31F3B_zps
Hopefully I'll get the engine in this weekend!
Edited by Plumbob
Plumbob
Soooo......
Tonight I put the engine in, didn't go too badly, probably only took an hour or so to get it in there, then another hour or so messing about.
Just one thing that's troubling me is the "good old" subject of master cylinder clearance... Or lack of it. I've had a look at a lot of photos of other people's cars and I know the shells vary quite a bit but mine seems to be very very tight. I'm 99.9% sure (I'll double check tomorrow) the LH engine mount is screwed in all the way so that the engine is as low as it can be, but it seems I've got clearance issues left, bottom and right! In the photos below the pedal box isn't actually done up at all, there must be a 10mm gap at the bottom where it should meet the bulkhead.
I'll have a go at grinding the tapped hole away on the LH end of the cam cover tomorrow and see if that allows the whole thing to drop down a bit. I reckon I'll have to take a load out of the belt cover too (as others have). I have already slotted the bulkhead holes "up and right" so I can shove the whole lot out of the way but it seems it's nowhere nearly enough.
462DC6E1-4887-4192-B5D8-870799FBCEDA_zps
1317CFEB-5A28-494A-ABAB-5FE73A5D8374_zps
I have to say I'm a bit deflated by it! Makes me want to put the 8v back in! :-)
speno
Put a pedal box on it ;0)
Looking sweet . you going to relocate the fuel filter or is there space?
Plumbob
You can shut up, this is all your fault! Haha
The fuel filter will fit but that's the last of my worries pal. Grrrrrr
speno
why have you painted the engine bay black ho ho
Plumbob
Cheeeeeky!
speno
I bet you will want the spoox sticker too from my goodwood to go with your spoox engine :D :D :D :D
Plumbob
Do you do refunds?
dobboy
Make sure you take enough off stuff to allow a bit of engine movement. When i first done mine i could feel knockin on my clutch and brake pedal, caused by engine hitting MC when braking hard.
Plumbob
I got up this morning and put all my toys back in the pram!
Did the usual mods to the cam cover and belt cover and it's now like this....
6145E75B-3998-48D6-A9C4-593748542D6A_zps
82FE64DE-A967-42D3-84F3-5430312BDE58_zps
Also got the windscreen back in today with the help from my dad and had a trial fit of the battery box. The driveshafts are also back in, gear rods connected and a few other little jobs.
All in all a good day!
