Pugnut
Best Jacking Point
Pugnut
i always use the back of the subframe to put in the axle stands but if i want to remove the subframe then where's the best place to put the stands?
cheers AL.
Guest Gar
I usually put axle stands under the sills, with a block of wood in-between to prevent damage.
Hasn't done any damage to mine.
Guest doughboy
same as Gar,
but without the wood :o
no damage, but best to be safe.
pacey205
Yup same as above as well.
Michael
perfecto pug
there is also a strong point, just behind where the rear subframe bolts enter the car
