omri617
How Much Power In Press Bench ?
omri617
Hi there..
Planning to build a press bench , and need some info if anyone can help..
Basically , I need to know how much POWER is needed normally to rescue a bushing , or control arm for example from a 205 for example , or any other car..
I must know this in order to plan the construction of steel .
Thanks in advance.
stef205
if i can push them in with a vice i wouldnt say you'd need alot.
omri617
500 KG?
I would just buy a complete unit unless you have all the components lying about for free.
omri617
All parts are here , just the H type steel beam. It doesn't cost much (around 30 pound for 6 meters)
A whole unit here costs around 300.
On the unit that I have , marked "4 tons maximum".
