lagonda
Front Sidelights And Dash Lighting Not Working?! 1989 Cti
lagonda
Got the Controle Technique (French MoT) tomorrow morning, so trust the car to play up now.
I recently changed the light switch stalk, and that seemed to solve previous lighting issues. I've got a third lighting stalk switch, so tried that...no change. So can be pretty definite it's not the switch.
Any ideas? Rear lights light up OK, headlamps, dip & main beam, also the horn, all work fine. On sidelight setting, only the rear lights work; no dash lighting, no sidelight dash symbol, no front sidelights.
Have tried fiddling with the 3 yellow earth connectors by the radiator, so it doesn't seem to be an earthing issue. Have washed car thoroughly including hosing under front wings.
lagonda
Fuse!
If I'd seen this sooner I would've suggested the fuse would be a good place to start as they all run through fuse #13 on the fusebox.
fuses.txt
g
