timstemi16
205 Mi16 Exhaust
timstemi16
Hi, just wondering what exhausts are good for a mi16 engined 205. Running just under 200bhp. Dont want anything too loud, heard standard are pretty good. Running a maniflow manifold and wondering what others use
Daryl1205
I'm using a magnex system I think it is in my gti6 205 exhaust isn't that loud it's more an induction roar you hear
stuart
I've got a pug racing exhaust on mine, not too loud, similar to a magnex but not as raspy perhaps.
Magnex's are too small really for the manifold, Being around 2" max, The Maniflow ones are 2 1/4" which is needed for these,
I know over the std maniflow system use a tiny centre box which I think is far too loud (No old jokes please) but the ones I supply the box is almost twice the size of the std one to keep the noise down as much as you can
timstemi16
Miles, it is actually one of your manifolds, verysimilar to a maniflow one iirc.
So you say that the system you do go well with it?
How much can you supply them for, i also need the bolts and springs for the flexi joint on the manifold.
Also while your here. I tend to struggle to get a nice tight fit on the two to one piece on the manifold, hence why ive bought springs and bolts and my exhaust has dropped off a few times and again when the car was stolen.
Any tips?
Systems drop me a PM with what you would like, Stainless or Mild?
The 2-1 Y section I tend to fit on with normal exhaust paste and spot weld a bit to ensure it won;t fall off, Bit overkill but I tend to go that route then it should never give any problems
