Jolly Green Monster
Gti6 Alternator Tensioner
Jolly Green Monster
Does the 306 one not fit when put into a 205?
Mine has a bit of ally with two holes in :)
Simon
stu8v
I run the full Rallye 306 setup, PAS but no air-con.
No issues.
Jolly Green Monster
I guess it was missing from the donor then :)
Will source one
dcc
I believe the problem was the belt length with the aircon removed. not everybody ran with the PAS. I have a S16 top mount and have a rose jointed adjustable brace to tighten the pulleys/belt tension.
If you're running with no PAS, the easiest thing to do is run a 6PK700 belt and use an eccentric tensioner on one of the unused M8 threaded holes to tension.
If you run PAS, then just run the so called "Rallye" setup (actually found on all later non-AC XU10's)
Jolly Green Monster
thanks, currently there is a bit of ally bracket from block to alternator which is just a tiny bit too short and very heath robinson lol
johniban
what model is the tensioner from?
Any motorfactor should be able to supply one.
Tensioner will be used on various PSA cars and no doubt plenty of other manufacturers too - early style GTi-6 tensioner will be fine for the job and most people use the one that they've taken off the engine when replacing the cambelt if it still is in good condition. You'll need to order another mounting post for the tensioner unless you've a scrap engine to pinch one from - they're still available from Peugeot.
quite a few dw engines use a similar tensioner and post.
johniban
oh ok i see thanks
what about the belt?
camgti
What about it?
Make sure the metal pipe work on the inner arch does not rub on the tensioner. Theres very little room
Cam
johniban
i dont no what belt to buy. :(
i searched that 6pk700 part number bit it brings up loads of diffrernt ones
If they all match the 6pk 700, then they're all the same (its not a part number)
Edited by welshpug
johniban
they dont all match up thats the problem
so they DONT bring up loads then :lol:
just go into a motorfactor, ask for a belt as close as you can get to those dimensions, it cannot be any simpler.
or even easier, just give your works parts man the standard 205 gti part number, it'll be a 4 rib belt but the close enough in length (698mm)
johniban
huh? no, it brang up loads of different belts with the same 6pk700 number, this is why i didnt know witch one to choose.
if they all came up with that description then they're all the same.
johniban
you dont understand,
i searched that 6pk700, and loads of different belts came up different lengths ect
so no, they arnt all the same
700 is the length, if they matched that, then they are the same length.
Edited by welshpug
jamie_1992
Just use a belt of a standard 1.9 gti with no pas that's all I did and works fine Evan when I needed a new belt just went to the motor factors and gave them my reg and they got it straight away
johniban
ok jamie thanks i will try that
