Ian205
1.9 Rear Brake Lines
Ian205
well folks looking for rear brake lines for my 205, the 1.6 lines are far too long , may consider braded lines anybody know where id pick up a set of these ? fyi i have 1.9 rear axle on my 205 .thanks
Edited by Ian205
if its still plumbed like a 1.6 then you need to use 1.6 lines, and then just run a full rigid line to the caliper, do away with the last short flexi to the caliper as per all later PSA vehicles that used the bendix caliper.
Ian205
it is plumbed as 1.6 back as far as the rear axle where it is removable just above the rear beam, its just the 1.6 from there back are way too long as they dont have to travel as far to the calipers as the drums, its just the lines from the connection at the rear beam to the caliper i need.
Solid copper pipe you mean? If so pop along to your local garage and get them to make you a couple, should be £20.00 ish
Simes
Or buy a tool, some 'ends' and copper pipe and make your own.
Did the whole of my car from m/c to compensators in an afternoon.
