allanallen
Cheap Low Comp Gti6
allanallen
Right, a friend of mine is building a turbo gti6 and wants to lower the compression a bit, he's got a pulsar t28 and external wastegate fitted up and is wanting to run around 12psi.
I suggested fitting some skimmed s16 pistons and rods as I know from pocketing them in the past they have a very meaty crown, not to mention the cars on the continent with de-comp plates running silly power.
Has anyone done this? AFAIK everything will bolt straight in but what sort of CR will we get with say 1-1.5mm removed from the pistons?
Cheers, Al
Doof
I'll be interested to hear how he gets on with an otherwise standard engine. What power is he expecting?
I'm sure a few have skimmed meat off the S16 piston to run a longer stroke crank, pip470 and Paul Higgs from memory.
Having measured how much clearance there is in an MI16 piston I bet you could run monster cams even with a longer stroke.
allanallen
I would think he'll be looking for around 280bhp
Welshpug, I'm sure in the past you've posted up the CR of a gti6 with s16 rods and pistons? Have you a rough idea what sort of CR it'd be with a mm or so old the piston?
yeah, not too difficult to figure out, I'll stick all the numbers I remember up.
RFS engine:
capacity=1998cc
total clearance volume given a known compression ratio of 10.8-1, [499.5/9.8]=50.96cc
combustion chamber volume is known to be 37cc.
gasket IIRC is 87mm bore x 1.2mm thickness [(8.7x8.7xPi/4=59.44cm2)x0.12]= 7.13cc
so dish + cutout volume [50.96-(37+7.13)]=6.87cc.
RFY engine:
Same block and crank, therefore same 1998cc,
total clearance volume given a known compression ratio of 10.4, [499.5/9.4]=53.13
combustion chamber vol - 40cc
gasket 87mm x 1.3mm [(8.7x8.7xPi/4=59.44cm2)x0.13]=7.72cc
dish+cutout volume = [53.13-(40+7.72)]=5.41cc.
Therefore, RFS head over RFY piston, using 1.2mm MLS o.e RFS gasket = [499.5+(37+7.13+5.41=49.54)] /49.54= 11.08-1
Take 1mm off S16 piston which is flat topped adds (8.6x8.6x3.14159)/4=58.08cm2 x 0.10=5.8cc to total clearance volume.
499.5+(49.54+5.8=55.34)/55.34=10.02-1.
there is a standard 1.45mm repair gasket, which would add 1.488cc, that would take it down to 9.78-1
allanallen
Well the standard 6 engine expired a few weeks ago so we're going ahead with this now I believe. Watch this space.....
Edited by allanallen
Al, would the 2.0 Mi16 head not be a better place to start, larger chamber to start with plus bigger stem valves?
What went wrong with the old one in the end, has it been post mortem'd?
allanallen
He hasn't got an s16 head, he's got a j4r but he'd rather use the rs for some unknown reason!!
Big end went, then really went and let the pistons bosh the valves.
I'd just get a custom head gasket made, say 2.5mm thick. There was a member on here from Argentinia who made them. Probably a sore point for UK members however.
Edited by petert
allanallen
I can skim the pistons for free peter and he already has a new headgasket.
wicked
@ Welshpug: in your calculation you assume that the pistons are sitting flush at deck for both engines; I don't know if they do.
Secondly; RFS has 158mm rods, RFY has 152mm rods, so probably you need to take of another 6mm from the piston??
edit: no issue, since the rods are taken from RFY as well... :blush:​
Edited by wicked
