Jolly Green Monster
Erratic Rev Counter
Jolly Green Monster
As subject. Flickers all over the place. Worse with lights on. Bad earth?
205 gti 1.6 with gti6 conversion.
Any common things to check?
Tried search but couldn't find anything
Simon
Rams_gti6
I had same, battery box was loose and battery was bouncing about all over!
Depends on how the Rev C is modified really, Could be a loose connection or a failing adaptor
Jolly Green Monster
Battery is solid.
Will investigate how it has been altered :)
rallyeash
Mine did this. Was todo with converting the tacho so it worked with 16v. I soldered the two contacts with a wire and it did it. (guide on here how to do it)
Never found out why as I bought a Stack Dash!
ORB
Mine only flickers for a nano second when I load the electrical current. I converted the clocks for the record.
Jolly Green Monster
It has also been modded on the back of the clocks.
If it were for a nano second only I wouldnt worry.
Will go over the wiring and worse case fit an after market rev counter as its currently unuseable as a rev counter
deathbringer929
mines nearly the same as this. if the engine speed drops below 1000rpm for a split second whilst the ICV gathers itself, my needle shoots up a bit then settles ok. wiring mod to rear of binnacle same as the guide on here.
Jolly Green Monster
thats also how mine has been modified. Will check it :)
