eddy_gti6
[Trackday_Prep] 205 8V Turbo Track Toy
looks interesting!
this is the bit I was after
eddy_gti6
Ah yeah i forgot about that, Give me 2 mins i will go hunt through my pile of plastic.
Looks like i have just gone and bought myself a set of next to new GAZ GHA coilovers B)
eddy_gti6
Sorry mate i have just about everything but that part
james20588
Hi mate I am also doing similar conversion what gains do you get from using gti inlet and 1.9 cam ?
eddy_gti6
1.9 gti cam has slightley more lift and duration and the gti inlet gives a better torque curve fr9m what I have been told, thats with the standard 48mm throttle body but I am upgraiding to an S16 throttle body what is 67mm if I remember fight what will allow more air in and should work better with my bosch 440cc injectors and TD04 turbo. Hoping for around 250bhp
james20588
Ah a see sounds good is there much modifying inlet manifold to make it fit ?
eddy_gti6
Yes as the gti inlet has square ports on so they need to be opened up and rounded off to suit the turbo head. Took me about an hour with a dremil bit on a compressor but im fussy and wanted it to be as good and smooth as I could get it. Then you will need to have a throttle body adapter plate made up so you can bolt the throttle body to the inlet as its not a direct fit.
eddy_gti6
You can see here what needs doing, Not alot to come off but you need to try and get a nice smooth finish so try port into the inlet as far as you can so you dont end up with a step from the square inlet to the bit you have rounded off to suit the head. I will pull my inlet back off when i get time and get a photo of it finished.
Edited by eddy_gti6
james20588
Looks good how did you go about making throttle body adaptor plate ? thanks for advise great project you've got ????
eddy_gti6
I havent yet. Still waiting on the throttle body to come. Will update when I make one tho mate
eddy_gti6
Bored tonight after work so decided to do something different and make myself some black masked headlights B) only got one done at the minute as its quite fiddly buy quite pleased with the out come. Dont think they will be too good at night but dont really plan to use the car in the dark anyway.
rallyeash
lights will be awful, I tried this about 6 years ago on a 205. you'll be able to see more using your hazards
eddy_gti6
Haha I wont really be using my car at night, mainly on track so lighting shouldnt really be an issue unless I do a track day in the dark?
rallyeash
Mot?
eddy_gti6
I can fit standard lights for mot if any issues but sure that can be worked around ;)
stef205
For mot purposes there legal as long as it doesn't effect beam pattern, which I'm sure it will effect it. If you want blacked lights you need the projector lights.
eddy_gti6
These will be fine as said above, the car wont be used in the dark. i can fit standard lights in for mot no problem at all, just basically have these for looks to be honest and most likely will only run 1 of them if any on track anyway
eddy_gti6
Yesterday i received my S16 throttle body from miles. Not a lot bigger than the standard one but every little helps and its a lot easier to fit to the GTi inlet as well.
Also finished my headlights off and rested my intercooler on the front of the car. Think i may have to get rid of this one and maybe buy a low boost cooler. Unless there is someone wanting to swap ;)
lol, that's far too big for a 205 8 valve turbo, have a look at what Tom Fenton and Henry yorke run.
eddy_gti6
I know that why I am thinking about buying a low boost gti6 cooler. Got any links to their cars? I know a few people who run evo coolers and seem to be fine tho?
stef205
Geeeezz!! That thing is huge! Abit ott, have a look on my thread at my intercooler it's just a cheap toyo sports one, build quality is fairly good. You'll have massive lag with that cooler
eddy_gti6
Am not keeping it, just what I had lying around. Al have a look when I am home. Quite fancy a forged low boost cooler off a s/c gti6
aldworth33
This is coming along well, next time I'm down at my mams in county Durham I'll need to have a look at this!
eddy_gti6
Your more than welcome to pop round for a look mate.
aldworth33
Cool she's at shildon so will prob down next month
