ORB
Battery Light On Dash
ORB
Again, I know that this has been asked a million times, but through searching, I cant find a decent answer!
Tonight I was running my car up to bleed up the coolant, and I noticed that when I put the heater fans on full bore that the battery charge lamp is illuminated very dimly in the binnacle.
I assume this is something to do with the heater somewhere itself, but I cannot see an answer or an obvious issue?
For the record, battery is showing clean charge of 14 point something while running so I see no actuall charge issue and it only seems to illuminate (very dull) when the Heater Fan is on full bore.
Throw me a bone dudes
glenwah
Could be a bad earth somewhere.
farmer
Don't they all do that? My two certainty did.
Saying that I put a new battery positive cable on at the weekend so will see if it's cured.
No they dont all do it, mine does not!
farmer
Better have a look for the fault then !!!!
Edited by farmer
