lynmorgan
Xu7 Alternator Setup
lynmorgan
I am due to have my modified 2 litre xu7 engine back from the engine builder on Tuesday with it booked in for mapping on the Friday. (last minute.com I know)
I was hoping to just have an alternator and tensioner without the pas pump etc, just wondering what setup anyone has used in the past?
I have looked on service box and it appears that there was a Peugeot partner 1.8 xu7jb that came with the an alternator setup with an adjuster and without PAS and A/C which would be perfect but the parts are no longer available.
johniban
Would the one off a 106 gti work? As they have just an alternator
Do you have any parts at all Lyn?
I'd imagine it wont be difficult to make pas brackets work with some adaption.
lynmorgan
I sorted this out, found a citroen berlingo 1.8 petrol with pas, used the mounts off that to hold the alternator to the block, used a cambelt tensioner that very conveniently threaded into a hole that was already on the mount to tension a standard 8 valve belt
