hillbilly
Twin Webber 45S
hillbilly
can you use the standerd fuel pump on a 1.9 gti to run 45s
Matteo
No, carbs need a low pressure fuel pump.
calvinhorse
Mine basically runs the injection pump, the oe lines make a loop with the filter on then 'T' off into two adjustable regulators to get it down to 2psi
It works and is simple
Crescent205
Yes a std injection pump is fine, and in fact a whole lot more reliable. You dont need the 2 regulators, you simply need a turbo regulator which can bring the pressure down low enough. This is the one http://www.demon-tweeks.co.uk/performance/fuel-pressure-regulators/malpassi-fuel-pressure-regulator-for-turbo-carburettor You simply come off the std filter into the reg then out of the reg into the carbs and put your return on the bottom of the reg.
hillbilly
So the one in the pic is the one i need?
calvinhorse
Dunno, it says 60psi down to 5psi everywhere I have looked says you need 2psi
Infect mine runs the filter king version of the above pump in the injection circuit then another filterking regulator with filter after that
Edited by calvinhorse
Furyblade_Lee
What sort of power gains would 45's get on an otherwise standard 1.6 / 1.9?
dcc
minimal gains on an otherwise standard engine.
Crescent205
Yes the one on the link and the pic is the same one that ahs been on my rally car for 8 years! i've also had std road cars on carbs with the same set up and pressure is fine.
Reebmit
Mines on 45 dellorto's running a filter king with standard injection pump, just perfect. I really like 45's having had them on all sorts over the years, I always run about 2.5 - 3 psi.
Edited by Reebmit
