Jolly Green Monster
[Trackday_Prep] My Track Toy
Jolly Green Monster
:) no problem.. I am in Maidstone but work all over..
Jolly Green Monster
Hullavington today, really enjoyed it,
probably the last time the red car will see the track and the road as drove it there and back.. only issue all day was brakes, really not inspiring confidence when the pedal was getting longer and longer.. rear drums need adjusting and possibly a wheel bearing but matter not as mild plan is engine swap wednesday to the dark grey car..
Few pics from today anyway
Simon
Jolly Green Monster
Anyone wanting a 1.9 gearbox or a tired 1.9 8v engine drop me a pm as will be available next week.
Simon
Jolly Green Monster
Engine be gone with you :)
E55FD16F-8834-45D0-9DF0-49D35A2D87BA_zps
DEEDA06B-356B-42AA-87C3-07AC7429B82F_zps
Need to solder this wiring conversion done by previous owner ? before dropping into the other car.
62A08A6F-0DD9-4E40-99B8-7348749B3AFC_zps
309 wishbones also fitted :)
Simon
Edited by Jolly Green Monster
crikey, that wiring was a bit of a bodge wasn't it!
Jolly Green Monster
Yeah I think they werent sure which wire went where so could swap them lol
The radiator relocation is even better pmsl
Jolly Green Monster
Also plan to do better than cable tie the ecu to header tank :)
Jolly Green Monster
engines now out the red one and gearbox swapped onto it and nearly ready to drop into the grey car
had to make a bracket for the crank sensor to sit in on the be1 gearbox which I am hoping we measured and have put in the correct place - soon see.
Jolly Green Monster
red car looking sorry for itself, havent progressed much this week as had a minor op on my back so can't lift or undo tight bolts lol
dcc
Why not fit the be3 setup? Far better cluth feel Imho
Jolly Green Monster
Because the gearset and diff is built into a be1
Jolly Green Monster
its a Peugeot sport close ratio gearbox (heavy duty semi helical gear set, long first, short 5th, works end case), BE1, ZF diff, 4.8FD bought from Alex on here..
If I swap it to the 4FD then I might look and see whats involved with swapping it to the BE3 casing if its possible to do..
Jolly Green Monster
decided the bracket for the crank sensor wasnt solid enough or accurate enough location wise (was intending altering it with a timing light) but as I had a spare box sat there had a rethink
CD9EC8CD-35AF-4F43-AC43-CF2E51F12ED0_zps
The red shell is stripped and now loaded on trailer ready to take to scrappy and weigh in, removed headlights since pic taken, found some rather bad welding on drivers rear quarter, looks like a large section had been replaced just behind the door.. eeekk.. glad I didnt do anything to test the strength of the repair.
Simon
how is the floor in that?
hope you've taken more off since the pic, there's a ton of useful stuff left!
Edited by welshpug
Jolly Green Monster
the floor looks to be okay.. there is some rust on the mounting point on the passenger side for rear beam.
I have remove wipers, wiper motor, tempted to remove screen and doors, got drivers wing to remove and rear lights.
Not decided whether to make it non rolling at the moment - its a time verses weigh in cost lol
how soon will it be going?
Friend of mine needs the left side section of the floor where the rear passengers feet would go, as we can see daylight through it where it had a dent from a ditch/hedge interface it seems several years ago.
it would be sacrilege to weigh in stuff like hubs wishbones steering rack beam etc, even if they need work, someone will give you more than weigh in price.
Jolly Green Monster
it looked find when I took carpet out but will double check
1.6 hubs, have another set of wishbones for sale and no one interested lol
rack I want as a spare but not made mind up to make it non rolling yet.. even no interest in 1.6 wheels with tyres!
cool thanks, I'll get my mate to take a picture of the bits he wants.
Jolly Green Monster
could possibly cut it out if I know how much is needed.. or make an offer and come and collect shell and remove the extra bits to sell ;)
you're a very long way away, and I haven't a working car till next week as I broke it earlier :blush:
Jolly Green Monster
oops lol
lets go with the cut a section out then
Jolly Green Monster
hoping to get back on the car monday :)
Will look at the section of floor on the old one Welshpug also
jamie_1992
Id be interested in a few bits before its off to the scrap yard not think I'm too far where abouts are you
Jolly Green Monster
cars about an hour from you - in chertsey :)
Jolly Green Monster
Box welded and fitted and engine in.
D654B874-DF30-4741-99F1-F55AC6AA36F6_zps
Clutch cable swapped, what a ball ache
9E140E17-EC53-4AFE-91A3-583493676D2D_zps
Simon
