dave205
Gti-6 Speed Sensor
dave205
I have a v6 in my 306 as most of you probably know already because of the cooling issues.
Another issue is i cabt get the speedo to work, does anyone know how to do it? I thought i'd wired it up right but obviously not! :/
use the three wire original 306 one, add a 12v switched and earth, signals to ecu and speedo, signal and earth already there.
dave205
I think i left that on the gearbox when i sold it unfortunately. The 406 2 wire one goes to box of tricks in the dash doesbt it?
yup, but the 306 doesn't use a box of tricks, hence needing to add a 12v+ and use the 306 sender.
dave205
Will the 306 sender fit in the 406 gearbox though?
<_<
srsly?
dave205
Well the reason i ask is the 406 is an ML gearbox not a be one
dave205
I assume one of these will do the trick?
Ebay item no: 281106553269
