roccorich
Exhaust Back Box
roccorich
My back box has a hole in it so ive been looking at new ones.
All the ones I have seen for ctis/gtis have the connection to the centre pipe where its just a bit of pipe with two slits that you clamp on.
However mine seems to have the kind with the two flanges that mount together. Like all my 106s have had.
Ive seen this kind also on the lower powered 205 exhaust on ebay.
So has somone fitted an exhaust from a smaller car to mine or is it possible to get both kinds of connection?
cheers
Rich
rallysteve
You need a back box for the later system. As said its the olive fitment. Early cars had a 3 piece exhaust with the sleeve fitting. Later cars had a 2 piece system with olive fitment.
You will find the backbox here (they generally supply bosal or walker):
http://www.leisureshack.co.uk/205-1-9-07-89-08-92_13511.aspx
for comparison here is the early system:
http://www.leisureshack.co.uk/205-1-9-gti-09-86-06-89_13510.aspx
And finally the very late version with Cat:
http://www.leisureshack.co.uk/205-1-9-01-90-01-94_13512.aspx
Steve
roccorich
Olive connection. ye thats the one.
Its so much easier with the right terminology.
Its an F reg cti thats had a 1.9 lump chucked in by a previous owner.
cheers
Rich
farmer
I got quoted a while back £35 delivered for a walker back box. (olive type)
roccorich
Im pretty sure that once I undo the olive connectiob that the front pipe will need replacing too...
Which is a pain as the rest of the front pipe is fine.
farmer
Centre section was £75 when I purchased.
New gasket and bolts etc needed to
roccorich
Thats why Im thinking of bodging/ welding it for a while.
farmer
Am sure you could do a repair in situ ?
rallysteve
Where from?
ECP do, or used to do Walker.
rallysteve
Every piece of exhaust related stuff I have had from ECP has been advertised as a brand different to that you actually receive so not going down that route again!
farmer
If anybody wants me to get exhausts from the factor its no problem, I would say call them yourselves but you wouldn't achieve the discount.
Ryan
Do the walker ones still have the divided downpipe, or have the switched to plain like everyone else?
farmer
I got the split pipe, but was told that was all the stock they had left on them.
roccorich
Its blowing on the underside where the brackets welded on.
Gonna see if anyone local can weld it.
If not ill try bodging with some alluminium tape we use at work.
works well if you can wrap it all the way round and back onto itself.
roccorich
All wrapped up...
Ive pulled the bracket off the exhaust as it was almost off anyway then wrapped around the silencer with tape. and used a huge metal clip to pull it back into place where its now missing a hanger. Took it for a good blast and it seems to have held up so far.
Had a better look at the rest of the exhaust and I was mistaken as it seems I have the sleeve type so when I do end up changing it I should be able to just change the back box.
