stufarri
Foglight Part No. 9682A5
stufarri
Hi - I have seen some foglights (dealer old stock) in a local car accessory shop at £19.99 per pair.
What do these fit please, I am hoping 309s!
Sorry, I don't have service box access.
Thanks in advance.
Slo
Just had a look only item coming up as 9682 are yellow headlight bulbs and bulb kits across the peugeot range, nothing for a5 though.
EDIT: There are also some fog lights showing for 306 and 605
Edited by Slo
Information about the search
0 document(s) found containing 9682A5 for other vehicle families
Are you sure that's the right part number?
just make an account stu, its very easy!
Service Box.peugeot.com
that part number does not appear on the parts files anywhere, I suspect that it is an accessory kit that you would buy from a dealer if my memory of the part numbers is correct.
on the pricing files however it does appear as "FOG LIGHT KIT" and still lists a price of £63.98.
unfortunately the accessories catalogue was not digitised for the older vehicles, so your best bet is to find a picture, or a dealer with a hard copy of the accessories catalogue, which unfortunately many have skipped years ago.
fog and spot lamp part numbers start with 620, 4th digit being 4 or 5
the 309 spot/drive lamp units specifically end in 4 77 for a clear lens, and 4 76 for the yellow type, fogs are 6205 77 and 76.
205 spot is 6204 74, or 6204 75 for the fog, 6205 for the yellow variant.
Slo
9682 a3 foglight kit for 306 and 9682 c3 fog light kit for 605
stufarri
Thanks lads, that was the part number was on the box.
Does the format 9682.A5 make any difference?
They look just like 309 foglights, I may take an old one in with me to see if they match, not looking likely though.
Edited by stufarri
format makes no difference, need a pic!
stufarri
Bugger, I will try to pop in tomorrow.
Slo
If you think they are for a 309 you could be right because last year i bought a brand new in original box phase 1 wing mirror and the part number didn't exist and was different on service box. As welshpug says a picture will give you a definite answer.
