stuart1298
Xu10J2Te Rebuild Help Needed
stuart1298
Right had my crank polished and new big end and main end bearings/shells, as the engine over fuelled and suffered bore wash I thought it would make sense to change the piston rings, fitted the new ones and put it all back together, turning the bottom end over and there was a lot of resistance, I took the pistons out and moves freely, there was no wear on the bearing/shells, turns out there is meant to be a small gap between the joins of the rings around the pistons, can anyone tell the size of the gap should be? I managed to snap one of the rings so gonna stick a new set in and have the block honed
DamirGTI
Definitely , the gap must be present .
Top compression ring - 0.2 to 0.4 mm
Second compression ring - 0.15 to 0.35 mm
Oil control ring - n/a (??)
Personally , i wouldn't do honing (if the bores are in otherwise good state - need to measure with bore gauge) , but just deglazing cylinder walls .
If the gaps of the piston rings are too tight - file the piston ring ends until the gaps suit the listed specs.
Out of curiosity , with which brand of the piston ring set you've been working had that where gaped too tight ?
D
DamirGTI
Have you actually checked the big end bearing shell clearances ?
Torqued big end bearing cap bolts properly ?
D
stuart1298
I can't remember in all honesty, I'm not 100% that what's caused the engine to be a bit tight, I need to order a new set as broke one when I tried to remover em, will i do any damage if in stick the pistons in with out the rings just to turn by hand to make sure that I haven't got the stiffness I had before, when i say stiff it took one hell of a lot if effort to move it, once it was moving it seemed ok, it was just the initial getting it to turn
stuart1298
Yup, everything it torqued up. What tollarence's should I get? I let the engine ship source the shells so they should be correct
DamirGTI
Well , if you want to check just the turning resistance again , fit at least one (better still two) used piston ring on each piston before running them into the bores .. otherwise you might scratch the piston skirts , and also the pistons will "wobble" around a bit on the insides of the bores without the rings while spinning the assembly via crankshaft .
Torque specs. for the big end bearing cap bolts/nuts are :
1. stage : 20Nm
2. stage : + 70 deg.
Big end clearances : 0.025 to 0.050 mm - you'll need "Plastigauge" to check that .
D
stuart1298
Old piston rings are long gone. Yeah got the torque settings the same as that. Will it be ok fitting 2 pistons give that a try, if no resistance remove them fit the other 2 and try it that way, I assume it's the rings as the main end bearings run perfect, so assume the big ends will be correct
stuart1298
DamirGTI
Maybe that'll be better choice .. aside from said , running the pistons trough the bores without the rings may fool you by creating even more resistance while turning the crank .
But , why not check the rings themselves inside the bores as this should be done ?
Arrange/mark the rings per each cylinder in which they where in (or chosen to be fitted in ..) , mark them so that you don't mix the order , compress the ring with fingers and slide it into the bore - use the piston up side down (with the piston crown facing down pushing on the piston ring) and push into the bore till the piston crown contacts the piston ring , push further up to the middle of the bore (middle of the piston rings travel inside the bore) to even out/level the ring inside the bore , slide the piston out and measure the ring gap with feeler gauges (per specs. written above) .
Edit : just understood now that you've binned the rings ! .. but do check the ring gaps when you buy new ones as described above :) .. after deglazing or honing the cylinders with thoroughly cleaned cylinder surfaces .
D
Edited by DamirGTI
stuart1298
Yeah found out how to do it, and even why it's important, with you giving me the gaps at the top of here I now know what I'm aiming for, cheers :)
DamirGTI
Need to do a lot of measuring when rebuilding an engine ! :) .. and thus having all the fancy measuring tools (which most of us don't ..) , also torque specs for bolt on engine components are critically important .
Sadly , i can't find any figures in my data for oil control rings .. but as a rule of a thumb , aim for 0.30 to 0.40 mm value (bigger gap wont hurt much here so can go a little bit bigger up to 0.50 mm)
Have fun !
D
stuart1298
Cheers mate, can only get 2 lots of piston rings at the mo, gotta wait a week for the other 2 :(
stuart1298
The rings are gorzette or something along that lines, got cylinders 1 & 4 in tonight, still a little resistance, but I no it shouldn't be to easy to move, other 2 should turn up tomorrow and all be ok,
