kaich
Mi16 Wiring Loom
kaich
I have a mi16 loom comes from a '89 405 1.9 mi16 with a motronic 355 ecu
according to this:
http://www.taylor-eng.com/ecu/motronic_intro.html
it should be a 3 row loom with a knock sensor (no lambda)
with topics like this
http://forum.205gtidrivers.com/index.php?showtopic=82724
I've searched in the forum and I think I have solved many questions, except a couple.
starting from the ecu side:
near the ecu multiplug, 2 wires; they are useless, right?
after we find the relais box: a black one (pump?) and a white one (injection?) with a fuse
and a green plug: what for?
To be continued
Green plug is obd.
kaich
go on:
2 wires:
a brown wire
a blu (or grey) wire with a yellow plug
30 and 7A so I assume oil pressure and starter motor. correct?
after we found the four plugs (injectors) and the icv plug
after
a short cable; it should be starter motor?
another 2 wires cable with no plug: red and green with no numbers: it should be for a 2wire knock sensor? Am I wrong?
I think you are on the right lines, check to see which pins on the ecu plug those two wires without a connect to.
Oil low and Alt are Brown and Blue 'ish', 405's never had pressure senders
kaich
after
thank you very much
what about the pic above?
it's really hard to see where the 2 wire cable goes to the ecu plug, it's all tapered very well.
any advice would very appreciate!
Use a multimeter, its very easy.
kaich
thanks, great idea!
so I found only 2 row pinout, where can I find a motronic 1.3 (3 row) loom?
There are several links about motronics 1,3 pinout comes from bmw and Porsche, but everyone is slighty different
something like this
http://www.scribd.com/doc/68042741/Motronic-pinouts
IMHO is different form the 355 ecu pinout.
thanks for the advice
EDIT
maybe this?
http://makovice.205gti.org/ecu
Edited by kaich
I have 3 row wiring diagram & pinouts but you'll have to wait a few days.
kaich
thank you very much for the usefull links! They are awesome! :)
kaich
little update
the 205 loom is slightly different from what I read here (it's a '88 1.9)
both brown connectors are different from the link above (there is also a red connector with other signals). Perhaps some wire goes to engine bay without ecu loom.
So i connected 30 e 30a (oil) alternator e starter motor , reverse light directly.
from the 405 loom I connected pin to pin to the dash:
stwiched + (2)
engine rpm (112)
fuel pump (76)
oil temp (30c)
ground (M)
and the big loom plug to the battery + (fuse box near AFM)
I don't connected knock sensor (actually I dont'h have one)
Connected:
earth 405 loom
earth ignition module
earth battery
earth brown connector ( M in A7)
to the gearbox
starter motor spin, but the engin wont'start
checked:
FP (is ok and there is 3 bar in the rail)
both loom relais (both inj e FP works fine)
dizzy is brand new
Tried with another ignition module (both blue bosch)
engine still don't start. there is no + 12 V in the coil plug
Any suggestion? Some check to try?
thanks in advance
kaich
auto update
brand new coil
checked again AFM, ignition module, relais, ground. with multimeter. checked continuity between AFM, coil and ignition module, 12 V and earth
connected everything of 2 loom multiplugs (water temp, etc)
coil 12,5 v ok
inj relè 11,6 V (?) but working
ecu chassis 6 ohm to ground ---> connected to the ground
still no sparks :angry:
kaich
let me Know you that I'finally solved
a fu###ng brand new distributor is the cause
the old one works fine
regards
kaich
