aronw2004
Respray / Zinc Phosfate Primer
aronw2004
Hi everyone, I have primed my engine bay with zinc phosphate primer after sanding back to bare metal.
My question is, is it ok to spray 2 part filler primer over this, and then spray the 2 part top coat?
NFS
Yes and spray it with etch primer before the filler/high build primer. that will give you maximum adhesion.
oh and good luck and show us some pictures.
Edited by NFS
aronw2004
cool, I will post some photos soon.
Ill test an area first just to make sure. the chap in the paint shop said that it would react due to the thinners in it and I would need to paint it with some isolator paint first.
johniban
If you have gone back to bare metal you will need to use etch primer first,
