Daviewonder
De-Rusting Hub Carriers
Daviewonder
Good read :)
Have you removed rust from hubs like that before? I used a similar product on mine and it removed the polished surface that the bearings run on, causing them to rumble like mad.
edit: split from http://forum.205gtidrivers.com/index.php?showtopic=152671&page=0
Edited by jackherer
Eh? Bearings are a sealed unit :unsure:
Daviewonder
The back of the bearing has a seal, the front of it doesn't.
calvinhorse
Lol you derusted it with the bearing still in place?
Edited by calvinhorse
Lol, have a look at a bearing tomorrow ;) two seals...
Daviewonder
No, I striped the ball bearings out of the hubs and de rusted the hubs.
farmer
Welshie I have to say you have been getting a bit up yourself on the forum recently.
Granted you may know your stuff but "pipe down " eh !
calvinhorse
So you left the race in?
Daviewonder
What you mean the race that's machined into the hub?
calvinhorse
On what car?
calvinhorse
Front or rear?
They should not be dismantled, theres your problem!
Got a problem or what?
You're only here to make money.
I can't see this thread lasting much longer...
calvinhorse
So then what happened? Did you buy new ones?
I've cleaned rear wheel bearings up before by sealing the bearing off with gaffer tape then gently sand blasting the exposed surface.
calvinhorse
That'll teach you not to be a hub painting pervert :D
Daviewonder
I got caught up in the moment after rebuilding my beam, ok :D
jord294
Have never had any issues when I've stripped down, cleaned out and regreased hubs.
