Paul_13
[Engine_Work] Puff The Magic Dervgon
Batfink
I think Paul needs to join us on one of our cross country drives Tom! Damn I need more power....
Paul_13
Think the cranks leaking either end :(
Daviewonder
i want to see a photo with puff making a cloud of derv
Pervert :rolleyes:
kyepan
so much pressure in cylinders, oil seal weakest link! moar boooooooosssssst.
dcc
Paul - I have a D turbo engine in a 306 if you're interested! cheap cheap! (and rebuilt ;) )
Paul_13
I'm not entirely sure it's the crank seal on the TB side because the belt is dry?! It's coming from higher up and from the engine side.
I think the easier option is to get another engine (maybe courtsey of DCC) and stick a td04 on it :lol:
Power does corrupt!
kyepan
WOOOOOSSSSHHHHHHHHHHH... in a cloud of derv
Paul_13
I think my car is due a new clutch :lol:
Going to put a manual boost controller on the td04.
All of the piping basically stays the same apart from the air intake pipework which is going to be 3" instead of 2.5"
I think my mate is sorting me out with an oil line for it
Buying an engine off Dcc to rebuild
Bit of a mini update for you all
johniban
these are awesome engines i love them!
ive fitted one to a suzuki sj with a rwd ldv gearbox
and had an old 306 with one, was really quick for a diesel i was suprised, but the high boost kept blowing head gaskets so i got annoyed and got rid
Paul_13
Why I've just bought some head studs :lol:
Think the t2 is having enough of 31psi!
Paul_13
recently picked up an engine off Dcc to rebuild and stick some Hdi rods in to handle the boost.
Looking to run the td04 on about 35psi, so the thickest conrods you can get are in order (hdi 16v)
got my air filter setup sorted, 57 x 63mm reducer elbow, a bit of flexi pipe, a tee for the oil breather pipework and a few joiners
Got to clock the turbo next and order up some gaskets so I can make an adapter plate
Oil line is sorted
Paul_13
Yeah :lol:
Speaking to a few people that have done this is proved a reliable 180ish Bhp setup.
People run the td04 at 45psi and they still have an engine left, but I'm not going that far with it
kyepan
Good point, these are ambitious plans
Paul_13
This is nothing compared to what other people have done to XUD's!
Uberderv
Still good though keep it up :-) Makes it even better that its veg powered and the people you pass will know it when they smell the veg smog ha ha
what do you get the TD04 from?
I'm getting something that runs a TD04 as standard :)
Uberderv
Off a Subaru I think.
Paul_13
Indeed. Subaru with 65k on thanks to a member on here :)
What you buying WP?
td_dan
Arp headstuds very nice
