dirtdog
Modifying Wishbones
dirtdog
I have been trying to find out about this for a while now and getting no results. I have messaged 'allenallen' and not had a reply back after reading a topic of his mentioning him welding a nut and bolt onto the end of the arm and using that (IIRC) instead of a balljoint?
I don't want fully adjustable arms that cost 400 quid (extortionate) ...but I also don't want to pay 60-70 a wishbone/arm for pattern parts. I think I remember reading that the materials to make the balljoint replaceable cost around 40 quid, but there is some chopping and welding to be done.
If anybody can share any information on this topic it would be much appreciated. I'm not the most clued up as ive never really experienced anything like this before so ...please be gentle :)
Thank you
ORB
I still don't understand how as a team of intuitive people, we have not found out the exact spects of the ball joint in order to make them replaceable.
I have 2 sets of arms here that need BJ's but I'm reluctant to sling them as I know a cure is just round the corner.
I'm going to contact Peugeot Technical tomorrow.
farmer
Good luck with that, they never want to know !
The thread is this one
http://forum.205gtidrivers.com/index.php?showtopic=149649
In case it isn't clear, they were a joint effort between Allan and I. I machined the arms and welded the sleeves to the arms.
I think the crux is really that if you have a milling machine, lathe, TIG welder and the balls to do it then these can be DIY. Otherwise you are paying the going rate of £400 or whatever for someone else to do the work for you, the cost going someway to compensate for the liability risks. The main stumbling block is the liabilty issue in the event of failure of a modified suspension arm, I'm happy to navigate in a car with the arms made by me, and I'd be happy to put them on my own road car, but I would not be happy to sell them to someone else, who could have a serious accident due to poor fitting or damage or 30k miles without so much as a spanner check or numerous other influences outside my control, all of which could see me in court.
If it were just as simple as pressing a new joint in or whatever then we'd all have been doing it long ago. Otherwise you are into machining and fabrication work on an existing component which leads to a substantially modified part in place of a standard one designed and tested by the manufacturer.
Finally really I'd say stop being so tight! The wishbones from Motaquip or whatever are decent enough value in my eyes, I know I certainly could not make one for £60!
farmer
I enquired about the motaquip arms they are NLA now also so the dealer said.
Plenty of others making arms (std replacement that is), and the o.e bush kit is still available at £25 or so.
Compbrake still do theirs at £250 odd iirc, but they arent as strong as the o.e arm nor do they clear the std arb still afaik.
allanallen
It's alright saying we should find a ball joint that fits but has anyone managed to actually press a ball joint out? I've tried several times with no joy.
Paul_13
Cybernck did from memory
minimaniacwhyard
im sure that i read somewhere about a bloke using a Renault one scenic think cant remember exactly. i would be interested in this as well
309jazzpanda
Using a megane/scenic ball joint could work but again it means chopping bits of arm and creating a hybrid of the two. Alternative could be to purchase rose joints and make your own if you are going down the "make your own" route
stef205
Yes thank you i have pushed one out :D the dont really push out as to sheer out! :lol: I had a idea on a 106 ball joint but the material on the arm would be insufficient. A 106 joint is much wider in diameter than the 205/309 joint.
742B15B0-0A34-4520-ADA4-ABD3973D32A2-176
E76C79BC-3BC2-464F-9A45-78443770DBA4-176
Since then i have really abandoned that idea and opted for the rose joint option.
693D4348-1643-4DFD-B784-A44B49A84E26-176
My progress has been some what slack but they should work.
allanallen
That's not all of it out though is it smarty pants? :P
Good effort on the roseys
stef205
well yes it is the rest is part of the arm! plus i was just going to mill the rest out, ha Gives you a idea tho :)
Edited by stef205
allanallen
Got you, no wonder I've never been able to part one then!
205wrc
Replaceable spherical joint arms have been done......tried in competition, checked and they've been fine. It can only be done to Non-genuine arms though as there is more material in the bottom ball joint to allow for machining. I have photos available of the work and prices etc. Obviously, it will be cheaper to modify a set of customers own arms than to supply a set of new ones, but it is a cheaper option than a fully adjustable rose jointed set...
ORB
Don't know if this helps, but I just got these two part numbers from the BJ's on some arms I have.
Clean one is a Q-Drive and the other I don't know what brand it was supplied as.
Wonder if ringing Delphi would get us onto the right track?
ORB
And this one is OE (I think)
How much meat is required? I have possibly half a dozen wishbones to choose from, whats the cost inc the drop pins?
I can get dan to drop them off for me, save the postage.
DamirGTI
Will be doing this as soon as i sort out my funds ..
Over here , there's a few machinist (with an gray hair and glasses !) who specialized in suspension components overhaul . Kinda dying profession/job though .
I've asked around which one of them is best quality/repair durability wise , and give him a call .
He said to me that he just press out the OE ball pin , machine the hole on the wishbone and make an threaded ridge on the top of the wishbone . Then , makes new ball pin with some kind of top hat over the ball pin and install the ball pin assembly back on the wishbone screw on type . In addition , adds an grease nipple on the bottom side of the ball joint .
He also mentioned that when the ball joint wears out again , he supplies new ball joints which are then replaced just by means of unscrewing the old worn joint off the wishbone and screw on the new joint .
D
Edited by DamirGTI
NFS
So looking at Allenallens thread you would need something like this?
http://www.mcgillmotorsport.com/3-4-x-3-4-right-hand-male-xmr12-ultra-high-performance-36/
http://www.mcgillmotorsport.com/3-4-x-3-4-left-hand-male-xml12-ultra-high-performance-51/
still tube with the thread cut into it
and some sort of roll pin, where can one of these be sorced?
allanallen
No point using left handed thread rose joints, just means you'll need a LH tap as well. They're not 'on car' adjustable or anything.
You need to take extra care when welding the bosses to the arms as you can easily melt through and damage the thread if you don't watch your job.
Drop pins will need to be custom made although I believe AB sell a set but they ain't cheap.
These were still available from Motaquip recently, we got one for Kezzers car & they are still showing as available on the motaquip ecat today;
The GTI (1.6 & 1.9) needs the VSA532/533 but a few people have found the balljoints to be rubbish recently.
Eurocarparts did sell ecap ones which afaik were the oe suppliers but last time I looked they were out of stock.
g
MikeC
G, are the Delphi ones any good?
Edited by MikeC
DamirGTI
I had a few pair of Delphi bones , not bad value for the money really .
Bushes aren't as good as OE (well neither one of the aftermarket ones aren't anyway .. slap on the OE bushes and job done) , surprisingly the balljoints lasted for quite a long time , much longer than TWR bones which i had previously .
Need to mention that the roads over here are a bit crappy ! loads of potholes for trashing the balljoints , and thus i always had them failing first whilst the bushes where still in "good" state .
However , they're a little bit shorter than OE bones (roughly 1/1.5mm if i remember) .. so you'll probably need to re-adjust the alignment afterwards , at least i had .. it was visible to the naked eye by the steering wheel being out of center after fitting them .
D
Edited by DamirGTI
