marcdimma
205 V6 Driveshaft Knackerd
marcdimma
Hi not been on ere for a long time ill update my 205 v6 conversion ASAP
I've currently knackerd my cv joint on my shortend v6 shaft
I thought there was some1 on ere that can shorten the v6 shafts for u
It's currently running 309 wishbones and standerd 205 hubs if any1 can help
Just replace the cv if thats what has worn out/broken.
Goliath
Paul - thirdtimelucky can shorten them, but I think he is very busy these days. Like mei said, if its just the CV joint thats knackered then just get a new (or used) V6 driveshaft and swap the CV joints over, it's easier then it sounds!
Mine went on my old V6 while I was in Croatia, luckily some of the people on the Eurotrip managed to source a Coupe V6 shaft and we just swapped the joints over :)
Edited by Goliath
allye
As above, this is what I have done recently. Because my car was too low it destroyed them so bought a good 2nd hand pair swapped everything over with some new grease now its perfect and takes all the abuse! (when it has a working clutch)
marcdimma
Thanks for the info ill give it ago
