fliprio
Rear Calliper Fitting Kit
fliprio
I have just taken the rear brakes apart on my H reg Gti (originally a 1.9) On one side it had only the retaining bar and clip, with no pad spring clips and on the other side it had nothing at all, just the pads pushed into the calliper. Having never taken them apart I can only assume bits have fallen off or just not put on properly.
I take it the bits I am missing is retaining bar and clip and 2 pad spring clips?
yup!
fliprio
excellent - thanks
Do Halfrauds do a kit?
S@m
Most motor factors do a kit, unsure on Halfords specifically. Last time i bought one with all the necessary clips, retaining bar etc. it was £8.
Don;t forget allot of Renaults use the same calliper as well
fliprio
Thanks, grabbed a kit from a local autofactors in the end, I cant believe the garage that last had the brakes apart didn't fit any spring clips or bars - I could understand one falling off but not all of them, one pad was making a bit for freedom.
All finished and hopefully the standard Brembo discs and pads I have put on will be better than the s*ite greenstuff pads and drilled & grooved discs I have taken off.
