cheesegrater
Bike Engine In A Car: Chain Drive To Prop Drive?
cheesegrater
Does anyone know whether there's a converter like a bevel gearbox to take a short chain transverse drive in to a longitudinal prop drive? Ive had a look on the net but they're all coming up with chain driven duff's, I don't fancy using a 8' long chain!
Engines going to be in the front and I want to retain the sequential box of the bike.
allanallen
Why not fit the engine longitudinal and save yourself the complication?
rallyeash
Don't bother with a bike engine. Not hugely powerful and no torque.
A 200hp 170lbft XU engine will be quicker in a pug
cheesegrater
This could work but I was thinking the weight offset may affect it and space in the engine bay. I need to decide which engine I want first I suppose. What do people think of a v twin'd car? Something out of a rsv1000?
They're not bad for the capacity though, piss all over yours bhp/litre ;)
you need two bike engines, or one with a turbo :D
NFS
I have looked into this as i had a saxo that i was breaking a long time ago, and there is nothing in the way of readly avaiable parts. you will need to design and get it made up, i was thinking about starting off with the chain sprocket, using that as a template for someone to design a way to mount a prop knuckle onto it, however i never worked out if the bike gearbox would even handle all the extra stresses of the prob as its not designed to take power like that.
rallyeash
Yeah I know Bhp per litre is much higher but there only a small engine!
People seem to have this perception that dropping a bike engine in a car will make it incredible as it revs to 14,000 rpm or whatever but the figures don't really stack up
Take an R1 engine for example in a 205
180hp
85lbft
850kg
211bhp per tonne and 100lbft per tonne
A lightly fettled GTI 6 engine with a pair of cams
190hp
160lbft
850kg
223bhp per tonne and 188 lbft per tonne.
I'm not saying bike engines aren't a good engine but there crap in a hatch back, impractical and running gear is generally a
cobble together job.
Unless you turbo one or chuck one in the front and one in the back but then it isn't really a normal drivable car anymore
rallyeash
Not Bhp per tonne though which is the only relevant physical thing
230hp + 760 kg = 302bhp per tonne
NFS
the only way these are fun is if it is in the boot so its drift able otherwise its just a laugh, lol
Twin bike engines are used in autograss racing a lot, two high revving fours are what you want, I have seen a couple of twin-vee-twin cars and although you'd think they'd be good due to more torque, in actual fact they were crap.
allanallen
So the op's front engine/rear drive option wouldn't drift?
Batfink
quad bike engine and 4wd
allanallen
Now that would be s*it :P
cheesegrater
Keep your silly ideas to yourself!
NFS
lol of course it would, but whether or not the gearbox would survive is a different matter, we all know that putting the engine in the back and using a chain diff would work and work well.
rallyeash
And handle s*it!
allanallen
You do realise that all the caterfields etc are front engined with prop to the rear, it's much more common.
NFS
lol where is the engine in that car? front or back?
allanallen
You been on the crack today or do your posts never make sense? :P
NFS
Nope they make never sense, lol i meant, was the engine in the 2 seater you posted the vid of positioned in the back of the car or the front?
rallyeash
Front, rear drive like all they all are!
NFS
Lol so that must mean there is a common conversion propshalf adaptor for the bike engines. answers the OP question
