dexter1002
Brakes No Bleeding
johnhenry
you can get larger bleed nipples, 13mm might be a push but ask at a factors
I had massive problems bleeding a system with 4 new calipers, new master cylinder & lines. was getting symptoms you were explaining from my brake pedal, not sure on your brake line setup, no-ones mentioned it yet so i assume the guru's who have already in this thread know its an okay setup.
i found my problem ended up being the eezibleed system, took about 10 separate bleeds with the tried and tested method and it was fine!
dexter1002
I think I'm just going to have to keep trying to bleed them,
I tried last night a couple times and I have a minimal bit on of breaking at the very end of the pedal.
If you've stopped the pedal from totally sinking you don't have any leaks any more (internal or external), you just have air in the system. One trick that sometimes helps as a last resort is leaving all four nipples undone with tubes going into jars of brake fluid. Leave it overnight and gravity will pull fluid through and dislodge any remaining air.
