fliprio
Rallye Rear Seat Covers
fliprio
Hi all,
I have been having a go a fixing my front rallye seats - they are starting to look good now, but I don't have any rear covers to repair only the foams are left.
I put up a wanted ad, but its turning more into a discussion thread so I thought I would start this one.
Dave from http://205gticovers.com/index.html has been a great help, hopefully he will post on this thread to talk about what info he needs to make rear rallye covers :-)
dch1950
Hi All,
Basic requirements are a set of covers (damaged or not) from which I can I can form a pattern (or patterns) to make up the covers. As I have said in another post - I have some info but is not enough to enable a pattern to be produced. Kindly get in touch with me or Dan if you can assist.
Once patterns are produced then this problem is resolved.
regards
Dave
vossy
Ill take a look at mine for you, I know it has a tear on the top I think but ill get back with some more info.
fliprio
Cheers Vossy, any info is much appreciated
Wallby
I have a rallye rear bench with covers intact (although a bit worn!) that you can have if you like? The foam has had a little nibble by a mouse too but im sure you could use them for what you need.
vossy
Heres what i have, backrest in quite bad condition, not sure if could be used for template? s*it phone pics due to light.
dch1950
Hi Vossy,
The cushion cover looks fine, and provided all main attachment points and listings and zips are place then the squab missing sections can be interpolated. (Hmmm - I like the sound of that B))
Dave
vossy
How long would you need them for?
dch1950
I would need to make the patterns. do a proto , sort out the fit, second (final fit - hopefully) proto. for the squab and the cushion. Probably a couple of weeks.
regards
Dave
